HELP: Facade brick wall
CRISTEL.MAJOR001
Message 1 of 8
CRISTEL.MAJOR001
Hi guys,
I have my project with brick walls.
I have tried everything i can to be able to see all brick patterns/image on all walls and no luck. Some show no brick just some color while others show the brick.
Could anyone please tell me how to solve this urgently? 😞
Picture attached.
Replies (7)
Message 2 of 8
hmunsell
Are you sure the walls are facing the right directions (brick out, vs toward the interior)
Howard Munsell
Message 3 of 8
Are the Brick Walls all using the same Material or different? If different, check the Material's Appearance tab settings. That's what determines the Realistic Appearance.
Message 4 of 8
constantin.stroescu
or , maybe you have walls in different Phases (Existing for first Floor and New for second Floor)and Phasing Filter to Show All...
Constantin Stroescu
Message 5 of 8
CRISTEL.MAJOR001
THANK YOU ALL FOR YOUR RESPONSES!!!!! 🙂
I FOUND THE LITTLE TRICK (IM A NEWBIE TO REVIT) AND FIGURED I CAN FLIP THE WALL BY PRESSING THE SPACE BAR! AND IT DID THE TRICK!!!!
Message 6 of 8
CRISTEL.MAJOR001
They were all the same phase just flipped inside 🙂
Message 7 of 8
CRISTEL.MAJOR001
They were all the same material for sure just flipped inward 🙂
Message 8 of 8
CRISTEL.MAJOR001
This was def the issue lol but instead of the clicking on the flip arrows I pressed space bar and it did the trick! Thank you 🙂
