Help creating pattern
mchi_topsoe
mchi_topsoe
Hi
I'm trying to create a quarter brick pattern.
*Kvartforbandt, Inverted U's
0, 0, 12, 240,266.666 , 228,-12
0, 0, 66, 240,266.666 , 228,-12
90, 0, 12, 266.666,240 , 54,-212.666
90, 228, 12, 266.666,240 , 54,-212.666
0, 180, 79.333, 240,266.666 , 228,-12
0, 180, 133.333, 240,266.666 , 228,-12
90, 180, 79.333, 266.666,240 , 54,-212.666
90, 408, 79.333, 266.666,240 , 54,-212.666
0, 120, 146, 240,266.666 , 228,-12
0, 120, 200, 240,266.666 , 228,-12
90, 120, 146, 266.666,240 , 54,-212.666
90, 348, 146, 266.666,240 , 54,-212.666
0, 0, 212.666, 0,266.666 , 168,-212666
0, 0, 266.666, 0,266.666 , 168,-212666
90, 0, 212.666, 266.666,2400 , 54,-212.666
90, 168, 212.666, 266.666,2400 , 54,-212.666
0, 180, 212.666, 0,266.666 , 108,-212666
0, 180, 266.666, 0,266.666 , 108,-212666
90, 180, 212.666, 266.666,2400 , 54,-212.666
90, 288, 212.666, 266.666,2400 , 54,-212.666
0, 300, 212.666, 240,266.666 , 228,-12
0, 300, 266.666, 240,266.666 , 228,-12
 Pattern repeats every fifth layer.
Any suggestions what i'm missing?
rxi.gg
You can easily create patterns with pyrevit plugin
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
