Help!! Corrupt File
Help!! Corrupt File
Help!! Corrupt File
Please can anyone help - I'm getting the below message on a model i've been working on all day. All the back up's come with the same message and audit isnt working.
I have attached the original file.
L.Maas
I managed to load it (partially?) into Revit 2019 (it mentions it was originally Revit 2015).
It is complaining about some families not being usable and those are deleted.
Unfortunately Revit is not backwards compatible so it will not be much help to you.
The best that could be done is export it to IFC (attached), which could be used as underlay.
Louis
Please mention Revit version, especially when uploading Revit files.
From what I read, Audit would need to be performed EACH time you Open the Project -- not just once.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Thanks! Are you able to send across the Revit 2019 file and I can open it on a different computer? The drawing was done I just need the render images.
L.Maas
Made it into Revit 2017, attached.
Louis
