Help accessing families
Message 1 of 8
hi there
I am operating on Revit 2018 - I am trying to access an Autodesk Family -- Window with Arch on it.  Please see the screen grab of what family I am looking for and the message I receive.  I assume the families are not loaded correctly to system.  Can anyone help me load these Autodesk Families?
Thanks in advance.
Helen
Accepted solutions (3)
Replies (7)
Message 2 of 8
hmunsell
are you loading them from the Insert ribbon > Load Family tool?
Howard Munsell
Message 3 of 8
Thank you,, I was doing it incorrectly.,, thank you!!
Message 4 of 8
hmunsell
not a problem... I used to do that all the time, in a door tools and click Load family when I'm really trying to load a different category. I always tell my staff  "when in doubt, use the insert ribbon...".
Howard Munsell
Message 5 of 8
MostafaElashmawy
This error appears when you try to load a family with the wrong tool. like clicking on the door tool then load family and select a window instead of a door.
to load a window family: "Architecture" tab >> Window >> load family, select the family.
if you are doing so but this error appear, so this family is set to a wrong category but that need you to share the family to check if it's only about wrong category or the family is not modelled as a window.
Mostafa Elashmawy
Message 6 of 8
Yes, the smallest error can waste a lot of time so all help is very appreciated.
I was in luck for an Arched Window.  I see there is no Arch Door Family in Autodesk Library.  I don't suppose you have any solution for that one?  See photo
Thanks much - if not don't worry, ill try to recreate 🙂
Message 7 of 8
hmunsell
you could take a standard door and edit the family (copy it first). should only need to edit the panel extrusion and the frame path (frames are usually sweeps).
Howard Munsell
Message 8 of 8
MostafaElashmawy
You can find some arch door families at Revit City and BIM object
below links
https://www.revitcity.com/downloads.php?action=search&keywords=arched+door&user_name=
https://www.bimobject.com/en/marvin-windows-and-doors/product/marvin_ulswatfd
Mostafa Elashmawy
