Cant Make Stair Error - Multi Level Stair - Landing Cant Be Done
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1572 Aufrufe, 5 Antworten
Hello Everyone,
Im trying to use multi stair, error warning pop up and showed that my landing cant be done, how to solve it ?
i attach some images, please see it
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Share the file.
Nachricht 3 von 6
als Antwort auf: ToanDN
check this file, im sorry i delete some part oh the object, but the stair still being the problem
(its a real project, so i need to kept it classified and the original file is larger than 300 mb), thanks for understand
Nachricht 4 von 6
MostafaElashmawy
I think the reason is the sketch based landing. Try redoing the stair from scratch without this landing.
Mostafa Elashmawy
Nachricht 5 von 6
ryley.g.h
Potential work around:
Draw the stairs for only one level with the landing, then hit cntl+c. Next, go to modify -> paste drop down -> Aligned to selected levels -> select all the levels where the stairs start (hold cntl and left click). Press OK.
Nachricht 6 von 6
I just make the landing type Same as Run instead of special.
