hello what is this called it makes my object inaccurate when rotating
qddmonterde
qddmonterde
it makes my component inaccurate when rotating. i think i click something but i dont know what is it.
Accepted solutions (3)
theslacollier
It might be due to the "Snap" or "Angle Increment" settings.
These settings can cause objects to snap to certain angles or increments, which might not align with your intended rotation.
RVT to the max
TripleM-Dev.net
You're snapping to the hatch pattern (of a floor), if the pattern is inaccurate then hide it in view.
handjonathan
Hi @qddmonterde
Thanks a lot for posting your question to the forums!   Has the solution suggested by @theslacollier @TripleM-Dev.net helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Mike.FORM
As @TripleM-Dev.net said, you are snapping to the pattern lines (model patterns can be rotated, drafting patterns cannot).
If you are trying to rotate your floor, you need to select it by grabbing the edge or by using select by face. Because your pattern is so dense you will need to zoom in so you avoid selecting the pattern.
