You have to run the command "Join Geometry" from tab Modify and click the beam and the floor (the order doesn't matter).
If the join is not the desirable after Join Geometry you have to run the command "Switch Join Order"
and click again the beam and the floor (the order doesn't matter also).
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
"join" is not active at all when pointing at the girder
Post the file so we can see.
Edit the family and set the 3d element to be visible for all detail levels (coarse, medium, and fine). You may also need to set the material behaviour to other.
I didn't understand about the meaning of the material. What should I put up specifically? I've set up everything else. Family file attached.
anyway... does not define for connection
