Mismatch between floors
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
lilachshahaf
481 Aufrufe, 6 Antworten
Hi, everyone,
I have a problem with Revit 2023 that I have not encountered before.
When I export files in AutoCAD for use by the constructor, there is a deviation in the position of the floors one on top of the other. When I make cuts and everything looks normal, but as mentioned in AutoCAD there are deviations.
What to do?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: lilachshahaf
Got before/after screenshots?
Nachricht 3 von 7
lilachshahaf
als Antwort auf: barthbradley
I think I found a solution.
Should be exported according to Specified in object styles
And not Indexes color
Nachricht 4 von 7
Huh? You have me scratching my head here. How does that cause deviations in the floor position between the RVT and DWG?
Nachricht 5 von 7
lilachshahaf
The AutoCAD file looks clearer, so you can see what all the lines mean
Nachricht 6 von 7
They don't even look like the same area.  Where is the pocket sliding door in the Revit's screenshot?
Nachricht 7 von 7
lilachshahaf
It isn't exactly the same place. but it ok because as I mentioned the solution was the graphics properties.
