Helical Massing
12 REPLIES 12
Message 1 of 13
KraiggC
677 Views, 12 Replies
Helical Massing
I'm trying create a light. It has square profile rotating hectically. I found a way to create a helix, except when I add a profile the twist on its path. Is there a way to manipulate this so I can have one side maintain the exterior? I've added images of what I have and what I'm trying to create.
12 REPLIES 12
Message 2 of 13
in reply to: KraiggC
Are you using HyunWoo Kim's method?
Message 3 of 13
KraiggC
in reply to: barthbradley
Did you modify your post? My email response is showing something completely different. But to answer the question I see below the method I'm using is from David Light.
Message 4 of 13
Yes. My initial reply wrong  -- at least it seemed that way upon re-reading your post.  I'm still not understanding though. That's why I'm asking how you did your helix.  If HyunWoo Kim's way, you used a 3-pt. adaptive and the repeater tool.  Is that right?
...okay, so David Light does it the same.  You're starting off with a 3-pt adaptive line and then repeating it over a divided surface with nodes.  Right?  So, what is it you want to do?  Originally I thought you just wanted the whole helix on its side, but I'm not sure now.
Message 5 of 13
KraiggC
I actually did a 9-pt adaptive spline. I've attached another image to better convey the twisting that happening that I'm trying to remedy.
Message 6 of 13
the twisting is the nature of the spline. Look at the family.  Turn the host that the spline is following along into a Ref. Line.  You'll see that the work planes of the Ref. Line twist on its axis as it winds about.
...a quick fix without redoing the work you've accomplished, would be to use a circle shape.  Just a thought.
Message 7 of 13
KraiggC
I'm not fully aware what you mean. The mass I have connected the adaptive spline to won't allow me to change it to a reference line. The spline itself also won't let me change it unless I'm in the family itself. I've attached the family so maybe you can screen shot what you mean?
Message 8 of 13
There's no form in Family10. Just a Spline.  Not really sure what you are doing now.  Attached is your Family10 with a 4x4 rectangular box which I made from your spline line and profile.
Message 9 of 13
Use a simple swept blend for a segment of the helix then multiple it.  No twisted faces.
Message 10 of 13
Corsten.Au
Try this.. Adjust the sizes
Grid U and V.JPGGrid U and V
Corsten
Building Designer
Message 11 of 13
KraiggC
in reply to: ToanDN
Um Toan.. how the #@$% did you do that?? Can you attach that? I've been trying sweeps and sweep blends forever to achieve this but they never gave me more than 2d curves.
Message 12 of 13
I did it at home so I don;t have the file wight now but it is quite simple.
Message 13 of 13
Is that all you are trying to do; create a sweep form? Did you open the file I sent you?  It has a 4x4 sweep form that can easily be parameterized so you can change its dimensions.
...or, maybe you are missing the Lock Profile tool???
