Height riser stairs
2 REPLIES 2
226 Views, 2 Replies
Height riser stairs
have problem with riser of stairs.
I've insert value 0.19 but remain 0.15 m in compontent.
Someone can help me?
Thank's
2 REPLIES 2
Sahay_R
Edit the stair sketch. Right now your stair has 27 risers. To get the desired riser height, you should have 21 risers. Change the number of risers in the sketch by erasing and redrawing so that you have 21 riser lines - then in the properties you will see that the riser is of the desired value.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
in reply to: Sahay_R
Thank's very much!
Forma Design Contest
