Heating & Cooling Load
goswamig315
goswamig315
How To do Heating & Cooling Load Calculation In Revit....?
SteveKStafford
You should probably start here and then follow the other links to see the whole process.
Steve Stafford
handjonathan
Hi @goswamig315
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
