Having trouble with a roof tie in
Message 1 of 27
I'm relatively new to Revit 2020.  I'm building an addition to a ranch style home.  The addition consists of adding a bathroom suite and an octagonal sitting area to the corner of the home. I cannot seem to get the tie in from the new roof to the existing roof correct. any help would be appreciated, as well, I would be happy to compensate in return.
Replies (26)
Message 2 of 27
constantin.stroescu
maybe this screencast can help you...It was made for a previous post but it could be also good for your case:
https://knowledge.autodesk.com/community/screencast/5579a75f-1f85-4ae1-a58a-e50db6c9e62f
Constantin Stroescu
Message 3 of 27
Why not change the plate height and have it above the roof(s) below -- instead of intersecting with the roof(s) below?
Just to be clear: I'm referring to the octagonal roof.  Are you?
Message 4 of 27
The addition was added to the corner of the house, therefore, the whole corner has to be connected.
Message 5 of 27
existing roof
Message 6 of 27
Post the file.  Might as well show you.
Message 7 of 27
Thank you
Message 8 of 27
My suggestion would be to do something along these lines. Pretty much what I was describing before.
Message 9 of 27
I like the idea of raising the octagon roof, it definitely makes things simpler. There's a skylight in the existing roof that I have to avoid, which is why I opted to use a hip roof for the addition. It's proving to be quite challenging to get the program to understand what I'm attempting to achieve. At this point, I'm not sure if Revit is capable of creating this roof.  Again, thank you for your help!
Message 10 of 27
Revit only does what you tell it to do. It doesn't think for itself.  If it did, we wouldn't be paid the big bucks.  😉
Message 11 of 27
I'm definitely still trying to learn it's language on this one.
Thank you for your help!
Message 12 of 27
constantin.stroescu
Is this close to what you want to achieve?
Constantin Stroescu
Message 13 of 27
okay, how'd you get that? did you have to do it in pieces?
Message 14 of 27
That's exactly what you had before. That's your design. I thought that was what you wanted to change.
Message 15 of 27
constantin.stroescu
I did it as I will do it on real life ,on site:
  • I've split the existing roof into two roofs:
    1. the left is the Existing, the right (as small as possible) will be also Existing but Demolished in New Phase
    2. then I create in New Phase a Roof by Footprint using your sketch and additional lines so to cover all the demolished area.
    3. In Sketch mode I've set the Slopes as seen in attached image
    4. In order to allow a "jump" on the eave border I made a split of the segment shown in my image and the right segment will have no slope
1.
2. and 3.
4.
and the result is this (shown in New Phase , shown Complete):
Constantin Stroescu
Message 16 of 27
I meant that's almost exactly what i was trying to achieve. I was asking how you got it? sorry.
Message 17 of 27
Also, thank you very much for your assistance!!!!!!
Message 18 of 27
Hey @Anonymous, out of curiosity, where's this aforementioned existing skylight located?
Message 19 of 27
I placed a temporary rectangle in the bathroom to mark its location. It's located right next to the toilet.
Message 20 of 27
I hate to ask, but where did they hide the "add a split line" function in 2020?
