Removing Portion of a Stair Landing
2 ANTWORTEN 2
Nachricht 1 von 3
keheidem
1186 Aufrufe, 2 Antworten
is it possible to remove a portion of a stair landing after it has been created?
I have a metal pan stair with a landing. The landing has a frame around three sides. one side connects to a floor. I would like to remove the frame where the stair meets the floor. I have attached a few images to hopefully better illustrate what i am trying to do.
Screen Shot 07-20-20 at 11.02 AM 001.PNGScreen Shot 07-20-20 at 11.02 AM.PNG
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: keheidem
Sure you can remove it. Some math is involved.  Might be easier to convert to sketch-based if it is not already.  Post the file.
Nachricht 3 von 3
You could just delete the landing support where the landing hits the floor, then edit the landing sketch and align the edge. But in reality, you would still need a support (that does not sticking up above the landing) at that end to attach the stair to the edge of slab.
