Hatch pattern present in new window on existing wall
5 REPLIES 5
tstewart
323 Views, 5 Replies
tstewart
How to remove the hatch pattern from a new window on an ex. masonry wall (the Detail Level is set to Fine)?
5 REPLIES 5
in reply to: tstewart
View Phase Filter = Show Complete?
tstewart
in reply to: barthbradley
tstewart
I had to put the windows on a different phase (Existing-None) to display correctly on the New plan.
You shouldn't have to do that, @tstewart.
Post your file.  Let's see what's going on.
tstewart
tstewart
It worked, although the Filter process didn't. I'm sure that I did not do the Filter procedure correctly.
It could be related to the Phase Filter/Override settings.
