Hatch origin point
Hatch origin point
nrmsdl
Message 1 of 8
Hatch origin point
nrmsdl
Hello. Does anybody know how to change the origin point for the hatch in Revit.
Thank you
Replies (7)
Message 2 of 8
David_Knight
You can not change it for a Drafting hatch pattern as far as I am aware.
You can move a model hatch by tabbing in and selecting a line in the linework then moving it as you wanted.
Message 3 of 8
RDAOU
@nrmsdl
Use Model Patterns intead of Drafting...These you can align and rotate using the standard Align/Rotate tool under Modify tab
Message 4 of 8
Pattycake_Kyle
Hey @nrmsdl
You are able to shift any pattern (drafting or model) by adjusting the X and Y origin values in the PAT file (2nd and 3rd values). [Here] is a tutorial we put together to help people understand these values and how PATs work.
As an example, I'm taking our .125 Radius Squiggle Wiggle pattern. Its based on a .50 by .25 base grid. Therefore, I can shift the top circle by .25 to align the top/bottom. We can add .25 to each X value of the upper circle, or subtract .25 of the bottom circle --- In the example I add .25.
With our live-edit view, you can see the exact changes before having to load them into revit to test.
shifting a pattern with x values in Pattycakeshifting a pattern with x values in Pattycake
Obviously if I kept going down the column for the other values, it would shift the entire pattern over .25. You can do this for drafting or model patterns, and for x and y values. You can do this in a simple .txt text editor or on a platform like Pattycake to see live edits.
You can as @David_Knight @RDAOU mentioned in Revit shift/align a model pattern (cannot do this for drafting), but I'm guessing you are trying to have the pattern aligned properly from the start (instead of shifting every single instance). If this is a useful tool and others request/comment for it, we can work to incorporate an easy global shift for patterns like we have done for Rotate. This what you needed?
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 5 of 8
RDAOU
Another promotional question/post lol
Message 6 of 8
Pattycake_Kyle
Not sure if you are implying I authored that question (I did not).
We simply have a good solution to many PAT problems, including free educational resources that can help many people get answers to common PAT questions. We really like to help people learn, I believe that is the intent of the Autodesk Knowledge Network (to share knowledge, which is why I'm here).
If you think it was purely a promotion, I did an awful job; everything I showed/described in my post is available through a completely free account on our platform.
www.pattycake.io
Message 7 of 8
RDAOU
No I simply meant another forum question which gives room to promote your cool tool
I tried it a couple of time...better/simpler than other addins
Message 8 of 8
Pattycake_Kyle
Ah, okay -- I apologize for assuming otherwise, I did not interpret your reply correctly at all - my bad.
And thank you for the kind words about the platform, its much appreciated.
www.pattycake.io
