Hatch earth Rotating 45
GHASEM_ARIYANI
Advisor Advisor
Message 1 of 24
GHASEM_ARIYANI
Hi
How in Revit , Hatch earth  Rotating 45 degrees??
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Replies (23)
Message 21 of 24
mail
That's correct. And exactly why we need both hatch patterns. Earth outside of the foundation is 45 and the earth that has been over-excavated and compacted should be orthogonal.
Message 22 of 24
bdroomcen
*EARTH45, Earth or ground at 45 degrees (subterranean)
45, 0,0, .125,.125, .125,-.125
45, -.033145, .033145, .125,.125, .125,-.125
45, -.06629, .06629, .125,.125, .125,-.125
135, -.06629, .08839, .125,.125, .125,-.125
135, -.033145, .121535, .125,.125, .125,-.125
135, 0, .15468, .125,.125, .125,-.125
Message 23 of 24
20510101388
*EARTH, Earth or ground (subterranean)
45, 0,0, .25,.25, .25,-.25
45, -.0663,.0663, .25,.25, .25,-.25
45, -.1326,.1326, .25,.25, .25,-.25
135, -.1326,.1768, .25,.25, .25,-.25
135, -.0663,.2431, .25,.25, .25,-.25
135, 0,.3094, .25,.25, .25,-.25
This is so great
Please help me with AR-PARQ1, I want to rotate 45 degree but I can't fix the code
*AR-PARQ1, 2x12 Parquet flooring: pattern of 12x12
90, 0,0, 12,12, 12,-12
90, 2,0, 12,12, 12,-12
90, 4,0, 12,12, 12,-12
90, 6,0, 12,12, 12,-12
90, 8,0, 12,12, 12,-12
90, 10,0, 12,12, 12,-12
90, 12,0, 12,12, 12,-12
0, 0,12, 12,-12, 12,-12
0, 0,14, 12,-12, 12,-12
0, 0,16, 12,-12, 12,-12
0, 0,18, 12,-12, 12,-12
0, 0,20, 12,-12, 12,-12
0, 0,22, 12,-12, 12,-12
0, 0,24, 12,-12, 12,-12
Message 24 of 24
Josh_Ferreria
working in Revit 2025. This solutions still works great!
