Handrail won't follow stair! Help!! Revit Architecture 2017
Message 1 of 15
Hi I've attached the following screen shots of a stair that won't comply!
If someone can help me... I've googled and to no avail....
Replies (14)
Message 2 of 15
Just close out of sketch mode.
Message 3 of 15
As attached.
Message 4 of 15
Place on Host; the Stringer in this case.
Message 5 of 15
I've tried on the inside, the middle and the outside of the stringer, which I believe would be the host.
Each way, I end with the same result, as can be seen in my screen shots.
Message 6 of 15
I now have the attached, the rail is now on the stair as required.
Problem is that is I also have a handrail in front of the door!
In addition I seem to missing the extension on both sides of the stair, it occurs only on one side!
Gotta love these stairs!! 🙂
Message 7 of 15
Do each side separately
Message 8 of 15
How?
Message 9 of 15
1. Place a rail on the right host.
2. Place a rail on the left host.
Message 10 of 15
Please see the attached. he horizontal mid span of the stair, isn't horizontal.  How can this be corrected? rails missing at the end of the stair mid rail missing at the top....
I had NO idea that this process was to be so difficult.
Thank you for you help..
PS: when adding a rail to the stair, I've been using Place on Host, which provides a rail all around the stair: both sides and in front of the door.  when I use sketch path on either stringer..... the railing goes horizontal!
Message 11 of 15
Can you share the file?  What version are you using?
Message 12 of 15
It normally isn't difficult. It might take some finessing though.  Can you post the rvt?
Message 13 of 15
Am done!
Post finessing... it worked out!
Yay... go team go!  🙂
Thanks so much for your help on this!
Message 14 of 15
Good to hear!
Cheers!
Message 15 of 15
Viveka_CD
Hi @Anonymous
Glad to hear your issue is resolved.
Please mark any posts that help with "Accept as Solution" and thanks!
