Handrail connection
Handrail connection
PAarchitects
Handrail connection
PAarchitects
How can I move the extension post @ both ends to the same height as the railing?
attached rtv of the stair (revit 2022)
syman2000
I notice the start & end post will always set below the railing. Even if you set the baluster height as 3', the start and end post will always cut off based on the railing diameter. So you have to add additional parameter to allow offsetting for the start & end post
