Group Editing Error
Group Editing Error
Message 1 of 11
Group Editing Error
On a number of occasions I get stuck inside group editing mode and there is a audio cue that keeps pinging as if there is an open pop up window. This happens most of the time when I'm editing walls inside group editor. When I move walls and close group editor there is usually the pop up window that says walls overlap. But in some cases that window only shows up for a spit second and disappears and then I'm stuck and not able to move anything.
Replies (10)
Message 2 of 11
Add a keyboard shortcut for Finish Group command and use it when stuck.
Message 3 of 11
Richard.P.Garcia
Hi @Anonymous,
Sorry to hear that. To understand more clearly the issue, could please create a screencast and send the link here so I can take a look at what is happening? For more information about screencast, check out this link: Autodesk Screencast. You can also share some screenshot.
Richard P. Garcia
Technical Support Specialist
Message 4 of 11
Well I can't really make it happen at will. It happens randomly and it's really annoying cause my the only solution is to force stop revit from task manager. Is there a way to reveal hidden pop up windows?
Message 5 of 11
Richard.P.Garcia
Hi @Anonymous,
Share some screenshots in case you encounter the error.
Richard P. Garcia
Message 6 of 11
I will. Also is there a way to add a keyboard shortcut to closing those pop up windows?
Message 7 of 11
Richard.P.Garcia
Hi @Anonymous,
If you are talking about the keyboard shortcut of closing the editing of group, type FG. Share screenshot of this pop up windows you are talking about.
Thanks.
Please hit the "Accept as Solution" button if my post resolves your issue and give "Kudo" as appropriate.
Richard P. Garcia
Message 8 of 11
Message 9 of 11
Hello @Anonymous,
Are you looking for the pop up window for warnings?
To see all the errors and warning Go to Manage>Inquiry>Warnings (see image)
Message 10 of 11
Nope, it's just in some instances when I close a group that pop up shows up for a split second and disappears, so from there I can't click OK to continue.
Message 11 of 11
Hello @Anonymous
I don't know why that pop up window disappearing so instantly but you can see those warning again by clicking the warning sign.
