Wall Editing Fatal Error
There were several times that Revit had a fatal error when I tried editing walls. It happens most often when editing at wall joins. What could cause this?
Richard.P.Garcia
Hi @Anonymous,
To understand more clearly the issue, could you please create a screencast and send the link here so I can take a look at what is happening? For more information about screencast, check out this link: Autodesk Screencast. You can also share some screenshot.
You may also do the following:
  1. Make sure Autodesk Revit is up to date with the latest updates installed.
  2. Update the graphics driver . Make sure you have a certified or the latest version of the driver installed.
  3. Turn off hardware acceleration and anti - aliasing . "R">Options>Graphics.
Please let me know how it goes.
Please hit the "Accept as Solution" button if my post resolves your issue and give "Kudo" as appropriate.
Richard P. Garcia
Technical Support Specialist
