Material Libraries
Material Libraries
Material Libraries
Material on one user did not appear because its not in the library.
All PCs have the same material library (Revit standard material library on local file) on their local file but there is one however that lacks some materials. All revits have the same versions and was installed on the same time. What could have been the problem and how do we solve it?
Chonghyuk.Lee
Hi @Anonymous,
Thank you for visiting Autodesk Forum and participating Answer day!
I am sorry to hear that you have an issue with material library.
I am not so sure what happened to a machine that you have a problem.
But could you check whether repairing Revit works for you?
Go to 'Control panel' and select 'Programs and Features' and click on Revit and Uninstall/Change.
Once installation windows pops up, please click on Repair
Or if it doesn't work, please try to clean uninstall and reinstall following the article below.
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
https://knowledge.autodesk.com/customer-service/download-install/remove-products/using-microsoft-fixit
If you have any questions, please feel free to let me know.
Thank you for your participation again. Have a great day and hope this helps.
If my post answers your question, please click the "Accept as Solution" button.  This helps everyone find answers more quickly!
Chonghyuk Lee
Product Support Specialist
Chonghyuk Lee
