Ground compass & Location problem of Sun Path
7 REPLIES 7
Message 1 of 8
1822 Views, 7 Replies
My ground compass of Sun Path do not sit in the centre of the project, please kindly help to solve it as I can't finish my homework.  The screen capture is attached.
I think it may due to the wrong location setting.  I don't know why the system automatically set the "494 Kings Road, Hong Kong"  to the sea.  It should be located at the blue dot area on the map.   I really hope someone can tell me how to solve it.  Thanks in advance.
7 REPLIES 7
Message 2 of 8
Just grab the marker and move it then.
Message 3 of 8
in reply to: barthbradley
Thanks! I did it last time, it works.  But suddenly the ground compass centre detached with the project site again.  Every time I grab back. but it change automatically.  May be after my sun location setting or may after other move.  It's really annoying.  Do you know why this happened?
Message 4 of 8
Glad I could help. That's how I usually roll. Why it didn't work for you, I have no clue. But, I've never been stuck in the ocean before. Maybe the ocean current? Ha!
Cheers and good luck!
Message 5 of 8
@Anonymous: did I misunderstand your last post? Were you saying that moving the marker worked, or did not work?
Message 6 of 8
To me it is center of the model extent  (the small element to the right of your main building counts too).
Message 7 of 8
in reply to: ToanDN
I think that's a small boat. I could be wrong.
Message 8 of 8
in reply to: ToanDN
Thank you very much.  You strict to the point.
