I am trying to use the grid guide to quickly align my floor plan views on different sheets. The view on the left is the first floor and the view on the right is the 2nd floor. As they are now on the sheet they are very close to being align by hand/eye.
See the grid line and the RED line on either view other being just under the 17 in mark defined on the sheet.
They are aligned similarly vertically as well.
The GREEN mark shows the grid intersection I am using in the project to base the alignment off of.
You can see how the left view grid guide is aligned to this green grid mark. However, the right view is off. If my sheets are aligned properly, should the grid guide location be the same?
