I modeled a hip roof along with a sloped glazing roof underneath it. I placed grids in the sloped glazing in order to place mullions that would act as the 4x10 rafters. When I placed the rafter at the hip, the mullion (rafter) is twisted along the grid axis. Is there a way to correct this and get to sit like the other typical mullions? I point out the specific rafter (mullion) on the pasted image below.
Gelöst! Gehe zur Lösung
Gelöst von studioconverge. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
I will try this. Thank you! Is that angle equal to the slope of the hip? Is the 27.94, in your example, a slope arrow?
Wouldn't Beam system be more convenient for you than slopped glazing?
@studioconverge wrote:I will try this. Thank you! Is that angle equal to the slope of the hip? Is the 27.94, in your example, a slope arrow?
Yep. That's the fastest and easiest way to find the slope. Use a Slope Arrow in Plan View and TAB-Select on the Hip. You only need it to find the angle to input into the Mullion Angle Parameter Field when creating the Mullion Type.
