Grid showing in one level but not another
2 REPLIES 2
diego.veloso.98
319 Views, 2 Replies
diego.veloso.98
Hi, I'm having a little trouble with my grids. Some of then works just fine, since I can see them in every level, but others I cant, like the images shown below. I already checked with they could be hidden, but they arent. Thank you !!
2 REPLIES 2
apjones
in reply to: diego.veloso.98
apjones
Grids are 3D datum lines. If it does not extend up (or down) into the level it will not show on that level. Cut a section and look to see the extents of the grid.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Pete
Select the girds, right click and Maximize 3d extent.
