Grid lines disappeared in 1 section but are visible in another section!
Message 1 of 25
I'm making a school project and I have 3 sections. In 2 sections I have all the grid lines and in one of the sections all the grid lines disappeared or are not visible. I already did all the things that I found in the internet, but I can't find the error. Could you please help me?
Joao
Replies (24)
Message 21 of 25
I've aligned the section A parallel to the reference plan and the gridlines on floor plan, but the gridline in the section didn't appear.
Message 22 of 25
In order to see the grids in a section, they need to be perpendicular to the section.  If the grids are curved, your section must be aligned (on top of) the radiating grid.  Being parallel won't help if they are curved.
Message 23 of 25
marc.khalil
Hello @Anonymous
I don't know if you still has this problem. I had the same problem with plans and I just the solution:
1. In a section view that you can see the all the gridlines, select all the gridlines
2. From the ribbon toolbar, choose "Propagate Extends"
3. Select the section view where gridlines are not visible
I hope this will help you.
Message 24 of 25
theoEB79A
I had a similar problem and found that when my elevation circle was not perpendicular to the grid the grid woud not show up in the elevation.
To resolve i re-made the elevations ensuring to align it to a wall that was perpendicular to the grid.
Message 25 of 25
reugenioWN28E
Community Visitor
Community Visitor
You are a gift from above
