GRID BUBBLE NOT SHOWING
Whenever i use grid, bubble doesn't show up.I tried using properties but in that its showing none.
Plz help
ennujozlagam
Hello, can you please post some screen shot for better understanding. Or are you in the correct view? Try to apply grid in plan view and see if helps. Thanks
chadwickt
Could the bubble be hidden? Try selecting a grid line and look for the check boxes on each end to unhide the bubbles.
semko_dm
Hi!
Can you attach a file with some of this grids?
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Alfredo_Medina
@Anonymous
Welcome to the forum.
Perhaps you don't have any grid head symbols loaded in the project.
The other reason could be that these other two parameters are not checked: "Plan View Symbols End 1" and "Plan View Symbols End 2". If these options are off, the grid will not show the bubble, even if the "Symbol" parameter is not set to "none".
Thanks lot...... Best info....
rafiu.oloruntele7HXPF
Observer
Observer
Thank You for this, you saved my day
