Grey Walls - with Wireframe setting
info
info
I've been given a model.
It's puzzling, all walls are grey, given I'm in wireframe mode?
Note:
  • I checked phasing - the ex. conditions are set to black.
  • Graphic Override - Nothings been changes.
  • Wall Property type - Course Scale Fill Pattern is set to grey. But when changing to fill to <none> does not change anything
Wireframe visual style does not make the wall poche disappear.  VG and turn off Walls > Cut Pattern, or change to Solid White pattern.
Check this:
info
Thanks for your post.
My apologies.
I realised I had .DWG as a background in model. It was the .DWG that was grey - not the wall fill in model
