- Mute
- Permalink
- Report
https://share.vidyard.com/watch/Sj5pdkB1fJN14zHbTLmLFs?
I recorded a 30 second clip of the issue , link above. Also I attached a before and after picture of the action.
Basically it is only Revit 2023 misbehaving, even after multiple uninstalls and install to see if it would make it go away.
It occurs even with a blank template.
Symptoms, during window select to the left (all) or to the right (per element) and drag on screen it distorts the graphics of any visible line or model, making lines disappear, get thicker, or overlaying of same image but bigger size, once you done doing the window select and stop the dragging it goes away.
Simultaneously 1 to 4 green squares the size of a pen tip appears on the top left corner of active window, they populate during the window selection and drag process.
The following versions work just fine, Revit 2020, 2021, 2022, & 2024
