green lines , not sure what is it and how to get rid of it
montesa3
montesa3
If you can tell, there are green lines on my floorplan but I am not sure how to get rid of it, hoping someone can help!
syman2000
Go to Object styles and change whatever those objects to black lines.
montesa3
mine are black. when I click where the green lines are it shows my flooring. i know the picture is green. this was an imported flooring from revit but i change the materials with it to change to my liking
Screenshot 2023-12-01 164409.pngare it clicks on my flooring which is strange
syman2000
Check the visibility and graphic override and filters to see if any floor is set to green
If this isn't the case, check and see if the object has silhouette override
If that don't work, try the phasing override
Maybe coming from a CAD Link/Import.
