When I print a sheet, the graphics in the print-out is undesirably different to the sheet in Revit.
This is the view in the Sheet:
This is the print out:
- This occurs when I print using a printer, or as a PDF.
- I've had no issues with this sheet in the past, this is a new issue, and I'm using the same version of Revit (i.e. 2020.2.9).
- And as far as I'm concerned, all print settings are the same in Revit:
