Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Graphic overrides / phase filters of linked models
Sahay_R
Mentor Mentor
Message 1 of 15
Sahay_R
Hello all
i have been tasked to create a set of colored overlays for a remodeling project. My workflow - create a blank project, link the shell and fit out models, and then apply graphic overrides for New and Demolished. The Demolished override works perfectly. New does not. Any ideas at art? I really don’t want to copy and paste elements from the files.
regards
Rina
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (14)
Message 2 of 15
Check Phase mapping of the links and make sure they match the host's.
Message 3 of 15
Sahay_R
Already checked. Phase filters have identical names. Demolished and Existing are perfectly overridden. New is not.
Rina Sahay
Message 4 of 15
hmunsell
what are you filter settings? can you share a screen shot?
Howard Munsell
Message 5 of 15
Without digging in to deep, you can create views in the linked models as you like and set the links the host model views to Display by Linked view.
Message 6 of 15
Sahay_R
Rina Sahay
Message 7 of 15
Sahay_R
@ToanDN @I can’t create views in the linked models - the client wants to see Demo in red and New in green. I can’t do that in the linked file without messing up a whole bunch of things
Rina Sahay
Message 8 of 15
Sahay_R
Is it just my imagination or we can’t edit Show All?
Rina Sahay
Message 9 of 15
No you cannot edit Show All and it is a good thing.
Anyhow, can you show the Phase Mapping of one of the links?
Message 10 of 15
Sahay_R
Rina Sahay
Message 11 of 15
hmunsell
it worked for me.... exterior walls are existing, Interior walls and kitchen is New and the counter in the top left is demo.  Update... My Bad.... I'm not using a link in this example. when i try it with a link i get the same results as you. the link is not taking the phase settings.
Howard Munsell
Message 12 of 15
Sahay_R
@hmunsell I’m having a feeling it’s something to do with my file. Did this work on a linked model?
Workaround - I linked the shell into the cutout ( the fit out has more info in it) and applied the filters. Walls from the shell still didn’t show up as green, but most of the info is correct.
Rina Sahay
Message 13 of 15
syman2000
Did you set your phase filter to Show Complete? I look at your phase filter setup. Show complete set as override for new, existing and demo. Normally I wouldn't change the default setting and instead create a separate name. Reason is if you use link by view, it will set to the link phase filter. This means you have to go into the link and check to see if the phase filter is the same as your current model.
Message 14 of 15
Works fine here.
Message 15 of 15
Sahay_R
Phantasmagorical as always, @ToanDN ! Much obliged.
Rina Sahay
