Graphic override for walls and curtain wall mullions
EdMilbourn
EdMilbourn
Hi
I use a graphics override (within a view template for elevations) to make wall patterns (brick, block etc) a mid grey purely for aesthetic/presentation reasons.
The issue I sometimes come up against is that the override is applied to curtain wall mullions too. I understand that these elements are part of a wall system so the override being applied makes sense.
However, where mullions are to be a particular colour or, in a current project, anthracite grey, I need them to display correctly. I currently us an 'in-view' element-by-element override as a solution. Just wondering if anyone has a less time consuming and more global solution.
Thank you.
EdMilbourn
....I meant to add that this is not a problem in a view template for perspective views where mullions and wall can be overridden separately.
GaryOrrMBI
Instead of directly overriding the wall category in the views and/or view templates create a filter to and use the filter to assign the overrides. With a filter you can have it exclude walls with the Family Name "Curtain Wall":
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
EdMilbourn
Many thanks. Exactly the solution I was looking for.
The only downside is I'm using Revit LT which does not offer filters - a crazy decision as filters seem a fairly basic graphic function.
I understand the exclusion of the more complex BIM features but view filters!?
Regardless of this, thank you Gary.
