graphic issue with linked dwg
andrea_ricci-ext
andrea_ricci-ext
I have a strange graphic behaviour with a linked dwg: not only the geometry is deformed as shown (the jagged ad out-of square shapes, the texts moved to the left…)
here's the original dwg:
I checked the distance from the internal origin and it's less than 16 km.
Revit 2023, NVIDIA quadro T1000 that "meets hardware requirements".
Any advice? thank you.
Replies (9)
jay_colcombe
As a quick check can you select all relevant information in the CAD file and use -wblock (to make new dwg file)
and try linking/inserting the new file in again.
Does the error still occur?
as you correctly state this usually happens when the CAD file is very far away but I have known it to be linked to incorrect units!
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Distorted-display-...
Jay Colcombe
Autodesk Certified Instructor
andrea_ricci-ext
Thank you for answering.
I ran a test with wblock with no luck, the units were already correct. The distance from the origin is less than 5 km
Thank you
syman2000
Upload the CAD file.
andrea_ricci-ext
Here it is, thnx
jay_colcombe
I opened the Cad File > Exploded all items and inserted into Revit without Issue, Hatches can be a pain in Revit from AutoCAD as they have their own coordinate System.  you could probably just get away with exploding the Wall Boundary Hatch Block?
Jay Colcombe
syman2000
The hatches and the line block is really far away from the origin when I edit the block. This will cause the hatch to behave weirdly. You can try exploding them or move the to the closer origin point using this plugin
http://lee-mac.com/changeblockinsertion.html
andrea_ricci-ext
so the distance problem is inside a block, not in the drawing itself which is close to the origin. Did I understand correctly?
syman2000
That is correct. Block has it's own origin point. If they look fine in the drawing but the origin point is far away, this will cause the Revit to display weird graphic.
jay_colcombe
I never bring hatches into Revit as stated they can have their own coordinate system and cause such problems as this!
i delete all hatches when preparing a model for Revit along with a Purge and Audit.
Jay Colcombe
