Gradient Fill Region With Two Colours
Duvylove
Duvylove
Hi All,
Can anyone explain to me how I can used two colours to achieve a gradient solid filled region as illustrated in the title block attached. The region fill in the attached titleblock was achieved using the AutoCAD hatch tool.
I look forward to hearing from you
Thanks, in anticipation
azad.Nanva
you can use the photo in title block,draw your fill region in photoshop or any drawing program and make the jpeg and png  and etc.
Save the DWG as PDF and import it into Revit.
Duvylove
Hi Toan,
Not a bad idea however I was just trying to figure out if there is a way one can actually implement the filled region directly in Revit
Duvylove
