Railings and ramps are appearing yellow in only elevation views
2 ANTWORTEN 2
Nachricht 1 von 3
htracey333
137 Aufrufe, 2 Antworten
Any type of railing used appears yellow in only my elevation views. The 3D view shows the normal color. These are the default railings in Revit. This also occurs for ramps and railings connected to ramps. I attempted to override the color of the railings but the yellow color still shows up on the realistic view for elevations.
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
jcurveyS6ZUF
als Antwort auf: htracey333
Can you add screenshots to show the difference between the railings in elevation and 3D views? And I assume you're using realistic visual style for both views?
Nachricht 3 von 3
RDAOU
@htracey333
I am assuming that this has nothing to do with phasing and you do not mean the Demo yellow...
When you say Realistic view that implies Render Appearance (+/-) & material. So I would suggest that you check the materials which you have assigned to ramps and railing components.
