cant modify base and top level constrain when 2 window of revit are opened on different display screen
5 ANTWORTEN 5
Nachricht 1 von 6
aaidinalimsyah
189 Aufrufe, 5 Antworten
when i open my 3d view on a separate window on a separate display, i can't set the ref plane/base level constrain on the properties of a column/wall and beam while im on my main screen with. when i click it, the drop down menu didn't do anything, and i have to close the 3d view window, or snap it back to the main program so it behave normally again, any solution? (this only happend when i move the 3d view window to another display screen, if i do it on tiled view mode within the same displayscreen, everything is normal)
5 ANTWORTEN 5
Nachricht 2 von 6
azad.Nanva
als Antwort auf: aaidinalimsyah
Can you share some screenshot or video ?
Nachricht 3 von 6
aaidinalimsyah
als Antwort auf: azad.Nanva
i attached a video. on it, when the 3d view window is open on another display, i cant open the drop down menu of bsae constrain, only when it on the same screen, same thing happened when i draw new column and wanted to set the base constrain.
Nachricht 4 von 6
azad.Nanva
change your main display and try it again?
Nachricht 5 von 6
aaidinalimsyah
i've switch the main display, still didn't work
also, this promblem only occur since i upgrade to revit 2025 a couple days ago, on revit 24 everything is fine :verwirrtes_Gesicht:
Nachricht 6 von 6
azad.Nanva
very odd problem ,I cannot imagine what the code or programing check the display before act and why?
