Google Maps image in 3D view
mairh_tsek
Message 1 of 8
mairh_tsek
Hello all,
I would like to create a more realistic 3D view placing my building in the 'real position'.
Is it possible to import a Google maps image in order to use it in the 3D?
Thnak you in advance!
Replies (7)
Message 2 of 8
cbcarch
-One method is to create a Decal, and then assign the Google Map image to it. Place the Decal on a horizontal plane/surface in the model. Note that you will need to scale the image carefully. Image quality may also depend on the map resolution.
-Decals only appear in Realistic and rendered views.
-Check here also: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
-Another method is to import the Revit model into Google Earth Pro.
Check here: https://www.revitcity.com/forums.php?action=viewthread&thread_id=36358
- One more method: If you have Navisworks, it has a Google Earth add-in. Export your Revit model to .nwc, then bring into NW and use the Google Earth add-in.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 8
Viveka_CD
Hi @mairh_tsek
Take a look at this similar thread
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
Message 4 of 8
mairh_tsek
@Viveka_CD,
Thank you for your answer! Where can I  download the Globe link add-in?
Message 5 of 8
Viveka_CD
Hi @mairh_tsek
This is a subscription add-in, for more information see HERE
Also, take a look at this plugin - CADto Earth.Revit and this thread for options.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Message 6 of 8
mairh_tsek
@Viveka_CD ,
I have an Autodesk subscription account but in 'All products and Services" tab I cannot fine the Globe Link Add-in for Autodesk Revit 2018 in order to download it.
https://knowledge.autodesk.com/customer-service/account-management/users-software/access-software-se... For example I cannot find all of these options that are described in the video.
Thank you in advance!
Message 7 of 8
mairh_tsek
@Viveka_CD ,
Is the Globe link Add-in available for Revit 2018?
I cannot find it in the list with the available subscription-add in for Revit 2018. ( http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-B51E757E-CEC1-48D8-B188-BF20EE19FC99 )
Is there any similar subscription-add in ?
Message 8 of 8
Viveka_CD
Hi @mairh_tsek
This may be a user profile or subscription issue. Can you repost on the installation and licensing forum for further feedback?
