glass effects in realistic elevation view
stephenwilliamsBSP
stephenwilliamsBSP
why can't we see the doors behind the windows but can behind the curtain walling.
all glass in the model is the same
there are no Visibility overrides
its only happened since revit 2022
see attached file
and thanks for your help
RDAOU
@stephenwilliamsBSP
They do look like 2 different types of glass though...Add to that the new Live render realistic mode...IE: you need to take the internal lighting into account..which I assume you do not have in that model
Why don't you attach that test model??
stephenwilliamsBSP
here's the test model. no internal lighting and they all seem to be the same material - unless I'm missing something
thanks
Do you have any masking region on the elevation in the family?
Edit Family, select Opening Cut and check Transparent in Elevation on the Options Bar.
stephenwilliamsBSP
no not this time!
cheers
