Getting floor tile to disappear when placing cabinets
When I go to Component to place a base cabinets in how do I get the floor tile (grid) pattern to disappear in that one spot where i put the base cabinet?
Sahay_R
Are you in a Hidden Line view? That will effectively hide the tile pattern.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Change your Visibility Graphics in the Family to show the Model in Plan View Course, Medium and Fine.
JasonKunkel
Is the floor tile actually a grid that is part of the floor or is it a fill pattern that was added later? If it is annotation, it will never get hidden by a model component.
Another thing to check is how the base cabinet was made. Most of the OOTB content is fine, but if it was custom, then the family might not have solids in it, or those solids might be turned off in the detail level or view you are in. You can put a filled region into the family to "cover up" what is below it if the solid is not visible.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
