How to import a archicad component file into revit
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2696 Aufrufe, 3 Antworten
Trying to download a product from bimobject - but it doesn't offer a revit option - only archicad.  Is it possible to import this into revit?
3 ANTWORTEN 3
Nachricht 2 von 4
loboarch
als Antwort auf: Anonymous
No it would not be possible to bring into Revit without something to open the ArchiCAD file and convert it to some kind of geometry Revit could understand. Revit does not support ArchiCAD content in any way.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 4
Sahay_R
Does it offer an AutoCAD DWG option?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 4
you can saveas the file in archicad in to ifc file and go to your revit in insert tab and select link IFC ,link the file after that select the object on revit and you will see in the link tab bind link select it only tick attached details then hit ok after 2 ok selection it would become group and ungroup it then vuwalah done.
