Getting errors that make zero sense when making family...
- Mute
- Permalink
- Report
Trying to make a window trim family. Literally the simplest thing I could possibly make but of course Revit has to make it as complicated as possible. You'll see in the image that I have an extrusion representing the piece of trim with model text indicating the size. I need to be able to change the length and width hence the "Trim Length" and "Trim Width" parameters. I also need the text to stay centered vertically and horizontally when the trim size is changed. Everything works if I delete the "EQ" dimlines circled in blue but I need these to keep the text centered. When I add the circled dims and try to change the "Trim Length", it completely breaks the model for some reason. I have no idea why its causing a conflict.
