I have modelled the beam below the columns(as shown in attached pic).
I want to get rid of beam lines showing inside the column.
also i cannot model beam at face of column as i need analytical model for structure analysis.
i tried changing object styles but was unable to get rid of them.
Please help me figure out this.
Thank you
Solved by pics.munmun. Go to Solution.
Solved by RDAOU. Go to Solution.
That depends of various factors such as
For the line pattern too several things to check
If you provide a section with levels and the view range you are using, it might be easier to understand what you have in the model and help you fix it
Material of Model Behavior
Beam shown as Beyond
