get rid of hidden lines
3 REPLIES 3
pics.munmun
1580 Views, 3 Replies
I have modelled the beam below the columns(as shown in attached pic).
I want to get rid of beam lines showing inside the column.
also i cannot model beam at face of column as i need analytical model for structure analysis.
i tried changing object styles but was unable to get rid of them.
Please help me figure out this.
Thank you
3 REPLIES 3
RDAOU
in reply to: pics.munmun
@pics.munmun
That depends of various factors such as
  • Material for Model behavior set in the family (Different material has different behavior ex: Concrete Beams join without a cut-back) Note: this is different than the finish material you set for rendering
  • Relation between Column and Beam...you mentioned that you have modeled the beams below the columns. You need to check their Extents (top and Bottom). Except for foundations and piles I would expect the workflow to be from Up >> Down...ie: Beam on top of the column
For the line pattern too several things to check
  • Check any overrides
  • Check view range and if the beams are shown as <BEYOND> (when beams fall between the the Primary Range Bottom and the View Depth they show in a Line Style called <Beyond> which is by default dashed
  • Check if the beam is below the slab and slab and is showing Hidden Lines through
If you provide a section with levels and the view range you are using, it might be easier to understand what you have in the model and help you fix it
Material of Model Behavior
Beam shown as Beyond
pics.munmun
in reply to: RDAOU
Please refer the attached .jpg files.
pics.munmun
refer attached.
Forma Design Contest
Technology Administrators
