get and control parameters from nested
4 REPLIES 4
tylerVD3L4
213 Views, 4 Replies
I made a detail family with a few nested detail families. How do I get the parameters from the nested family into the parent / host family and control them there? I tried making a parameter with the same name, and it doesn't do anything.
4 REPLIES 4
tylerVD3L4
in reply to: tylerVD3L4
here's the family. I don't need it fixed though, I want to know how to do this
tylerVD3L4
nevermind, i figured it out. I had to select the nested family, and then click the button next to the parameter in the properties panel
tylerVD3L4
family working correctly attached. The forum moderator could delete this post if they think it's neccessary
mhiserZFHXS
You need to create new parameters in the parent family, and then select the nested family and associate its parameters to the appropriate parameters in the parent family. So once they're associated, you change the parameters in the parent family and it pushes that info to the next family.
Forma Design Contest
