- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I've done extensive research and followed instructions from multiple forum posts with no success. I'll explain the situation and then what I've tried already. I've been working with the engineer to remedy this situation and have continued to fail. I'm attempting to link a Civil 3D CAD file into Revit. The CAD file is a 3D model which will be linked into a Revit model containing site and building elements. Additionally, I have access to both Civil 3D and Revit and I've attempted to manipulate the CAD file with no success. I'm also having the same situation when I try to link a different CAD project too. Lastly, I can't link the CAD file into Revit to publish coordinates to the Revit file because the extents are too great.
I've already tried recommendations from both of these posts:
The engineer has also tried:
- Sending the file with the surface "blocked" into the drawing to remove the external data reference
- followed these directions - https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-import-Civil-3D-O...
- Exporting the files to IFC
I've performed the following:
- turn on and unfreeze all layers
- bind/insert/remove all xrefs
- changed the origin of the dwg to 0,0,0
- Zoom extents and removed extra geometry
- explode all
- create a new block and create new dwg
- cut and paste into new dwg
- purge and audit
- removed geolocation from the CAD file
If anyone has ANY additional solutions or recommendations please let me know. I'll also update this post if I figure out what the problem is. DWG for reference. Thank you!
