Hello Everyone,
Does anyone know how can I enter a latitude and longitude (decimal degrees) in the the survey point in Revit?
Why is it grey out? I am hoping to use the coordinates from google maps and enter the latitude and longitude, so we have the geolocation of the site ( not just for shadows studies per manage tab-location).
Thank you!
Solved by ToanDN. Go to Solution.
Acquire Coordinates from a Georeferenced Survey.
Alternatively, set your Location via the Location and Site dialog box under Manage Tab.
If you have the exact address, you can enter it and Search via Internet Mapping Service, then you can have a more precise Lat/Long (switch to Default City List to see it).
BTW: to access to that Sun Settings dialog box I'm showing above, press the Sun icon on the View Control Bar.
Thank you barthbradley! I am familiar with the process you mentioned Manage=>Location. However that doesn't seem to have any impact in the N/S or E/W fields in the survey. ( That would make the most sense to me to if they could relate, but they don't) . The main challenger here is how to enter my latitude and longitude in the fields under 'Geolocation' Lat' and 'Lon' are greyed out.
You can't. That is populated when you Acquire GIS Coordinates from a Linked Survey. You said you didn't have one.
Nope. I don 't have a georeferenced survey. I only have the latitude and longitude which I got from google maps.
Can I do anything with that to enter on the survey point fields? Could I translate decimals degrees( google maps ) to feet and inches( since they are not same units, that would not work, right?)
@dpatriotaW9CR9 wrote:Nope. I don 't have a georeferenced survey. I only have the latitude and longitude which I got from google maps.
No. Why is this so important to you? You stated originally that this was related to doing Shadow Studies. The Origin of the Survey Coordinate System has no bearing on this.
I am looking to get an easy identifiable geolocation( from google maps) to place a revit project in to a real world location using the survey point. ( My statement in the beginning was not to use as mere shadows study).
@dpatriotaW9CR9 wrote:My statement in the beginning was not to use as mere shadows study.
Oops. My bad.
Do you have AutoCAD? You can create a DWG with the Geolocation and acquire its coordinates in Revit.
Hey ToanDN.. that worked very nicely to what I was hoping!
Thank you very much for the suggestion!
What is your choice and reason picking the GIS coordinate system in this overwhelming list they offer?
If you are going to go that route, Specify Coordinates Before Linking Site Data
Specify Coordinates Before Linking Site Data | Revit 2019 | Autodesk Knowledge Network
...unclip Survey Point.
I would use an UTM (feet or meter depends on your country).
