Geolocation fields grey out in the Survey Point
dpatriotaW9CR9
Message 1 of 20
dpatriotaW9CR9
Hello Everyone,
Does anyone know how can I enter a latitude and longitude (decimal degrees) in the the survey point in Revit?
Why is it grey out? I am hoping to  use the coordinates from google maps and enter the latitude and longitude, so we have the geolocation of the site ( not just for shadows studies  per manage tab-location).
Thank you!
Replies (19)
Message 2 of 20
Acquire Coordinates from a Georeferenced Survey.
Alternatively, set your Location via the Location and Site dialog box under Manage Tab.
Message 3 of 20
dpatriotaW9CR9
I am afraid I don't have a georeferenced survey. Do you know if there is a way of entering the latitude and longitude? Thanks for you time!
Message 4 of 20
Manage Tab=>Location
Set Default City
Message 5 of 20
If you have the exact address, you can enter it and Search via Internet Mapping Service, then you can have a more precise Lat/Long (switch to Default City List to see it).
Message 6 of 20
Shadow at same time; different channel 😉
Message 7 of 20
BTW: to access to that Sun Settings dialog box I'm showing above, press the Sun icon on the View Control Bar.
Message 8 of 20
dpatriotaW9CR9
Thank you barthbradley! I am familiar with the process you mentioned Manage=>Location. However that doesn't seem to have any impact  in the N/S or E/W fields in the survey. ( That would make the most sense to me to if they could relate, but they don't) . The main challenger here is how to enter my  latitude and longitude in the fields under 'Geolocation' Lat' and 'Lon' are greyed out.
Message 9 of 20
You can't. That is populated when you Acquire GIS Coordinates from a Linked Survey.  You said you didn't have one.
Message 10 of 20
dpatriotaW9CR9
Nope. I don 't have a georeferenced survey. I only have  the latitude and longitude which I got from google maps.
Can I do anything with  that to enter on the survey point fields?  Could I translate  decimals degrees( google maps ) to feet and inches( since they are not same units, that would not work, right?)
Message 11 of 20
No. Why is this so important to you?  You stated originally that this was related to doing Shadow Studies.  The Origin of the Survey Coordinate System has no bearing on this.
Message 12 of 20
dpatriotaW9CR9
I am looking to get an easy identifiable geolocation( from google maps) to place a revit project in to a real world location using the survey point. ( My statement in the beginning was not to use as mere shadows study).
Message 13 of 20
 My statement in the beginning was not to use as mere shadows study.
Oops. My bad.
Message 14 of 20
dpatriotaW9CR9
No Problem, Thank you for your commitment to this tread!
Message 15 of 20
You can still convert Lat/Long to UTM.
Good luck.
Message 16 of 20
Do you have AutoCAD?  You can create a DWG with the Geolocation and acquire its coordinates in Revit.
Message 17 of 20
dpatriotaW9CR9
okay, That is a good idea. I will try! Thank you!
Message 18 of 20
dpatriotaW9CR9
Hey ToanDN.. that worked very nicely to what I was hoping!
Thank you very much for the suggestion!
What is your choice and reason picking the GIS coordinate system in this overwhelming list they offer?
Message 19 of 20
If you are going to go that route, Specify Coordinates Before Linking Site Data
Specify Coordinates Before Linking Site Data | Revit 2019 | Autodesk Knowledge Network
...unclip Survey Point.
Message 20 of 20
I would use an UTM (feet or meter depends on your country).
https://www.maptools.com/selecting_a_coordinate_system
