Geolocated cad file with point cloud
robertovalentino
Message 1 of 13
robertovalentino
Good morning,,
I was hoping you could help me out with a small problem that I have.
My client sent me a point cloud file, and a DWG file, a file with the point cloud linked in.
Now, the DWG file is geolocated but the point cloud is not.
is there a way to link the point cloud in Revit in the exact position after acquiring the coordinate system from the dwg file?
thank you in advance
Roberto
Replies (12)
Message 2 of 13
Georeferenced? Use this method first to bring the DWG into Revit:
https://knowledge.autodesk.com/support/revit/learn/caas/CloudHelp/cloudhelp/2021/ENU/Revit-Model/fil...
Then Link the PC by Auto-Shared Coordinates.  That should work.
Message 3 of 13
Actually, I don't think it will work in this case.    I would definitely Link the DWG into Revit via Specify Coordinates at Point though.
Message 4 of 13
robertovalentino
Hi @barthbradley
Thank you so much for taking the time to investigate it; I really appreciate it.
Unfortunately, the Point cloud is not georeferenced. Therefore any "link with shared coordinates" would put it in the wrong place.
I think I found the way, even though I do not like it that much.
On the CAD file, which has global coordinates (WGS84), I can select the point cloud, and I can see the coordinates (distance of the PC origin from the Autocad file Origin).
Now I link the DWG and acquire the coordinates.
Then I link the Point Cloud with "shared coordinates."
This will bring the point cloud to the wrong spot, of course, but I know how to move it because I have the coordinates (distance from the survey point).
Any comments?
Thank you!!!
Message 5 of 13
Like I said before, I would bring the Geolocated DWG into Revit via Specify Coordinates at Point - not by positioning the DWG in Revit and Acquiring Coordinates.
...the workflow is described in the link I provided above.
Message 6 of 13
robertovalentino
Yup I saw that
but if I specify the coordinates I have the numbers but not the coordinate system 😉
Message 7 of 13
@robertovalentino wrote:
Yup I saw that
Huh? What does this mean?  "I have the numbers but not the coordinate system"
Message 8 of 13
Can you share what you were given by the client?
Message 9 of 13
- Insert the PC in the geo CAD file
- Draw a Cross1 at the point cloud origin in AutoCAD
- Move the PC to align with CAD and copy the Cross1 with it to create Cross2, save
- Link the Geo CAD in Revit center to center
- Link the PC in Revit center to center
- Move the PC in Revit from Cross1 to Cross 2
- Acquire coordinates from CAD
Message 10 of 13
robertovalentino
@barthbradley
Oh sorry, I realise that was a built vague. Let me elaborate a little bit.
Using “coordinates at point” I can set the position of the survey point but I can not set the name of the coordinate system. It is just an XYZ point. If you interrogate revit about that, you will see:
Coordinate system = Unknown
I am used to set the coordinate system correctly in Civil3D (in this case UTM33 North - WGS84), and push it in Revit when I acquire coordinates.
Using Acquire Coordinates you will see the coordinate system used in the properties.
Message 11 of 13
robertovalentino
Unfortunately I can not share any file
Message 12 of 13
@barthbradley
That's because you didn't Link the DWG into Revit via Auto-Shared Coordinates afterwards.
Message 13 of 13
robertovalentino
Thank you so much @barthbradley
That maks a lot of sense 😉
