Generic Model pattern will not align in project
Message 1 of 20
I have created a Generic Model Splash back see below, when i bring this model into a project. the pattern is not able to be aligned to the flooring. what have i done wrong here?
Replies (19)
Message 2 of 20
How is the pattern made?
Message 3 of 20
You cannot align a model pattern of a loadable family in the project environment.
Message 4 of 20
is it a Model Pattern? I'm seeing edges. Looks like individual panels -- possibly arrayed.  Maybe a Line-Based Family?
Message 5 of 20
It's is an extrusion 10mm thick with a 600x600mm pattern.
Usually i do this as a 10mm wall face and dont have this issue just wanted to have something abit more solid then a wall finish all the time.
Below you can see the bath tiles and shower tiles dont line up and wont allow me to align them.
Message 6 of 20
You have to create them as thin walls or wall sweeps in the project then you will be able to manipulate the model pattern alignment.
Message 7 of 20
...or @Anonymous, if you want to do it as a loadable family, model the full bathtub surround in the family. You could even parameterize it to meet different bathtub sizes and backsplash heights.
Message 8 of 20
I like this idea,
only issue is then in a situation like shown, i wouldn't be able to then align the bath tiles with the shower tiles. Pedantic i know but some clients will request things like this.
Message 9 of 20
Alfredo_Medina
Yes, you can align the lines of the tiles on the floor with the lines of the tiles on the wall. For the floor, use a floor element with model hatch pattern (not a pattern-based family!), and for the tiles on the wall, use a thin wall type with a model hatch pattern. Then, align the tiles.
Message 10 of 20
FAIR59
the alignment can be realised by an offset parameter in the family.
In the family:
  • make a reference plane (horizontal).
  • give the plane a name.
  • give the distance to the Ref.Level a labeled dimension.
  • set the workplane of the extrusion to the reference plane.
  • align the surface pattern to the reference plane.
  • constrain the pattern to the reference plane using a locked dimension.pattern_offset.PNG
Message 11 of 20
@FAIR59: Interesting approach, but I can't seem to get it to work. Want to post your family?
Message 12 of 20
FAIR59
enjoy
Message 13 of 20
@Anonymous wrote:
I like this idea,
Think about it this way:  if your buy prefab units with tile built-in then the pattern should be in the family; if you build them on site then the pattern should be in project to fit various conditions.
Message 14 of 20
Oh, I see what you're doing now, @FAIR59. Basically, you are changing the Extrusion Start in a round about way.  Clever.
@Anonymous: I think you ought to look at @FAIR59's family.  It's pretty much spot on to what you were asking about.
Message 15 of 20
Alfredo_Medina
But what is the purpose or advantage in spending time making a family with a grid pattern instead of simply using a floor or wall with a model surface pattern?
Message 16 of 20
Dunno, @Alfredo_Medina.  I'm not advocating the approach and don't use it.  We use walls and floors.  But still, I found @FAIR59's approach a clever and applicable workaround.  I'm glad I learned about.  Maybe I'll find a use for it. Maybe I won't.  Always fun learning new stuff though.  Smiley Wink
Message 17 of 20
Alfredo_Medina
It´s like making a parametric detail item family with rows and columns, to produce a schedule, instead of using the built-in schedule feature.
Message 18 of 20
oh, I don't know that I would go that far, @Alfredo_Medina. It's just a little trick.  Whether or not it rises to the level of being a useful trick, is probably slim.  But, for the moment, it's interesting.  Smiley Wink
Message 19 of 20
I still think your right, wall and floors are the best way to answer my question. I have been doing my splashbacks this way.
I tried to duplicate the outcome using a family. I like the idea of using families for things, i just think they are a more solid approach then using walls and having to constantly disallow join for the main stud framing. Also when you have parts of a wall with full high tiles then a 100mm skirting tile then another tile maybe at a second height again. can get fiddly with walls.
Message 20 of 20
JordiCC245
great @FAIR59 !!
let's try the next level: can you do it in both directions (X, Y)?
by the way, I have a problem about it.  I need to make a hole in that surface, but then the offset parameter stops working (I don't know why)
